Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
SYNC Module in 2011
This is a discussion on SYNC Module in 2011 within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Ah... SYNC, oh what fun. The in-dash port worked once for me; now when plugging in a flash drive, the ...
Old 01-22-2016, 11:23 PM   #1 (permalink)
Junior Member
Default SYNC Module in 2011
Ah... SYNC, oh what fun. The in-dash port worked once for me; now when plugging in a flash drive, the activity indicator just does one quick "flash" like there is a bad connection. Bought a plain cable and an adaptor thinking it's just a bad dash cable and same result. Plugged plain cable into USB2 and the drive lit up and functioned perfectly. Wanting USB1 to work, I thought an update might fix it--nope-- it just deactivated the USB2 voice command (hint hint, if you're happy with your current version DO NOT UPDATE; the chick sounds like she has marbles in her mouth when saying "Bluetooth Audio" as well).
DirtRacer37 is offline   Reply With Quote
Tags
sync
Fuel Pump Module jlauth Ford Raptor Problems and Questions Forum 3 04-14-2015 10:12 PM
M&R dimmer/strobe module MandR Automotive Ford Raptor Lighting Modifications Forum [GEN 1] 73 07-30-2014 12:48 AM
Body Contol Module srs Ford Raptor Problems and Questions Forum 8 01-14-2014 10:05 PM
Recall Alert: 2011 Body Control Module pirate air Ford Raptor Recalls | TSB's | SSM's 0 05-16-2012 04:44 PM
Yes, there IS an update for the 2011 Sync HoustonRider Ford Raptor Audio/Video/Electronics Forum [GEN 1] 27 08-22-2011 09:08 PM
