I've searched pretty hard here and across the Googles (yes, all of the Googles, every one of them...). I went to hop in the truck today and it wouldn't even attempt to start. I got in succession:
From what I've found it could be a poor battery connection, a key issue (using the spare typically resolves it, and also using remote start possibly), need to pull fuse 18 or the 3rd brake light got moisture in it. I have checked all of these scenarios in succession, and no luck. I get climate control, radio works, arm / disarm works, lights work. The truck will not turn over, remote start will not engage and using the spare key doesn't change anything.
From what I've been reading on the 3rd brake light issue, it was limited to 2010's mostly, TSB was out on it, and it causes the first error message on the display, but doesn't keep the truck from running.
I'll need to flatbed this thing to the dealer as it is not running now. I live in AZ, we haven't had rain in maybe 2 months. I pulled into the garage yesterday after running around, no issues at all leading up to this morning, no indication anything was wrong. I replaced the battery about 2 weeks ago. I got the truck washed almost exactly a week ago, and I've driven it maybe 300+ miles since then, and started it / turned it off probably a dozen times since the wash, 20 times since the battery, no issues at all.
I'm stumped, anyone have any idea on how to get this running so I don't have to get it towed and wait several days for them to look at it? I cannot determine what the underlying issue might be here. Truck is a 2014 with 30,500 miles, still under warranty, just wanting to avoid the multi day extravaganza. Have an appointment to get my shocks rebuilt Wednesday, this could put a damper on that.
- Hill Descent Control Fault
- Starting System Fault
- Low Oil Pressure
- Service AdvanceTrac
- Engine Overtemp
- Generic wrench icon
