Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Mechanical Problems and Questions Forum
Sponsored Ads
Starter Problems
This is a discussion on Starter Problems within the Ford Raptor Mechanical Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Register to remove these ads. It's free! Has anybody experienced any starter issues? This started about a month ago. There ...
Old 02-13-2012, 12:23 PM   #1 (permalink)
BlueSTI's Avatar
Full Throttle Member
Default Starter Problems
This started about a month ago. There was one occasion where I went to use the remote start, and instead I heard a LOUD grinding noise! It started the second time, so I thought maybe it was a strange fluke.
Well last week, it did the same thing... so I went out to the truck to start it, and it did this 5 MORE TIMES! I thought it was done for... then it started on the 6th try. I'm retarded, and didn't think to video at the time!
Well, again this morning... grinded once, started the second time. Clearly my starter is going bad. The only problem is, like my electrical gremilns, this is hit and miss and not always easy to reproduce. Do you think the dealer will investigate purely based on my description, or will they try to reproduce and start my truck a million times in the process?
My next goal is getting this noise on film with my iPhone... the noise is incredible! Probably wakes the neighbors up.
Raptor Expeditions team member
"I do my best proofreading right after I hit REPLY"
BlueSTI is offline   Reply With Quote
Old 02-13-2012, 12:25 PM   #2 (permalink)
Dane's Avatar
Mine did this last week - it was only a week old at the time (150 miles maybe?). Scared the crap out of me. It hasn't done it since. I can't say that it was the starter for sure, but that's what it sounded like.
I'm very interested in what you find.
2012 Black Tuxedo Black SuperCrew Raptor
2001 Suzuki GSX-R1000
2008 Mercedes SLK 280
2003 Jeep Rubicon
Dane is offline   Reply With Quote
Old 02-13-2012, 12:26 PM   #3 (permalink)
BlueSTI's Avatar
Freaking loud, isn't it?!?!
Old 02-13-2012, 12:47 PM   #4 (permalink)
Dane's Avatar
Yup, and it's not like you can just stop it like when it happens on an older style car where the computer doesn't control the starter. I honestly wasn't sure what it was, but when I read your thread I figured that yup, that is what it sounded like.
I've also had a time or two when it just honks and doesn't start. I know I read about that on another thread before I got my truck, but I haven't re-read it or looked into it.
2003 Jeep Rubicon
Old 02-13-2012, 12:59 PM   #5 (permalink)
BlueSTI's Avatar
If you're using the key, you actually CAN interrupt it... but not with the remote start, a good full second of loud ass grinding!
Old 02-13-2012, 01:01 PM   #6 (permalink)
NY SCREW's Avatar
will missle dropkick you
i had it happen one time so far in 3,000 miles. i was at work an prior to dressing down popped my head out to start it an warm up......it sounded like metal grinding i freaked out thought it was my starter ,tried it again after looking an everything seemed ok an nothing thing started right up.......it scared the ever loving god out of me seriously not something i want to hear my truck do again
2012 white screw|bakflip F1|Bedrug|rubberized sprayed custom rear wheel wells|tints|PDP contour mudflaps
Originally Posted by GJMcManus View Post
"It is, because it is"
Deep drunken thoughts
Greg McManus
-Greg
NY SCREW is offline   Reply With Quote
Old 02-13-2012, 01:05 PM   #7 (permalink)
I'm going to assume that the dealer is going to try and reproduce it in order to diagnose it. That's how 50% of their issues are resolved. The other 50% is "sorry, couldn't reproduce the issue so we adjusted this *BS*"
Humvee21 is offline   Reply With Quote
Old 02-13-2012, 02:41 PM   #8 (permalink)
jdowens1's Avatar
Ford Senior Master Technician
sounds like flat spot on the flexplate. I had an 04 that would grind from time to time after two starters exploded decided to look closer and found two flat spot on the flexplate. Seen it happen randomly from time to time. It might not be but ya never know.
jdowens1 is offline   Reply With Quote
Old 02-13-2012, 02:49 PM   #9 (permalink)
Dane's Avatar
But on a one week old truck?
2003 Jeep Rubicon
Old 02-13-2012, 06:54 PM   #10 (permalink)
pirate air's Avatar
will plunder your booty
Try and reproduce it. If it wont act up then just replace the starter and inspect the flex plate when the starters out. About how I'd go about it... Really nothing else you can do/test, can't fix a problem if its not there at the time.
pirate air is offline   Reply With Quote
How many miles do you have and what problems have you had? BIRDMAN Ford Raptor Mechanical Problems and Questions Forum 167 11-23-2011 06:53 PM
If you havin' girl problems I feel bad for you son. I got 99 problems... Humvee21 Other Vehicles 55 11-21-2011 02:08 PM
New Wheels new Problems... tnsbruce Ford Raptor Wheels & Tires Forum 23 06-07-2011 09:27 AM
Big Rig Amber LED problems dbmaster RECON Truck Accessories 18 02-04-2011 08:53 PM
Fully Driven Auto Network
