Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Sight grinding from front right tire
This is a discussion on Sight grinding from front right tire within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
My truck started making a slight grinding noise from the front right tire. Sounds like it could be the hub ...
Like Tree7Likes
Old 09-09-2013, 01:18 PM   #1 (permalink)
whtrapta's Avatar
Ostrich Wrangler
Default Sight grinding from front right tire
My truck started making a slight grinding noise from the front right tire. Sounds like it could be the hub maybe? Anyone know or have experience with this?
Just when you think your done modifying... your not.
whtrapta is offline   Reply With Quote
Old 09-09-2013, 01:26 PM   #2 (permalink)
when turning or all the time?
blood is offline   Reply With Quote
Old 09-09-2013, 01:26 PM   #3 (permalink)
pat'sRAPTOR's Avatar
Hmm that's odd. Have you taken te tire off to check your brake pads and rotors. It could be the hub bearings it's easy to pull the hub off and look and since it'll be off you could replace the bearings lol
pat'sRAPTOR is offline   Reply With Quote
Old 09-09-2013, 01:31 PM   #4 (permalink)
Yukon Joe's Avatar
Yeah, sounds like a wheel bearing.
Yukon Joe
GLRE Support Raptor
WWW.RUNRAPTORRUN.COM
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 09-09-2013, 01:33 PM   #5 (permalink)
whtrapta's Avatar
Ostrich Wrangler
How easy/hard is it to replace the wheel bearing?
Old 09-09-2013, 01:57 PM   #6 (permalink)
Well the bearings I think are pressed in so that might be the hardest part of it all. Everything else is easy to take off
Old 09-09-2013, 02:17 PM   #7 (permalink)
Steele16's Avatar
I destroyed a wheel bearing and it made more sense to replace the hub
Originally Posted by sabumaru View Post
As a europeaan the amarican offroad scene is new to me
But i like the way you people do things
Steele16 is offline   Reply With Quote
Old 09-09-2013, 05:58 PM   #8 (permalink)
pirate air's Avatar
will plunder your booty
Trying replace just the bearings is nearly impossible because the ford hubs are a sealed one piece design. The hub assemblies are fairly easy to replace. Pull the tire, brake caliper, brake rotor off. Remove the wheel speed sensor from the hub housing held in with a allen head bolt. Remove the cover and stub shaft nut that holds the cv axle in the hub. You'll probably have to tap on the cv snub with a hammer to free it so it will slide out when you remove the hub. Remove the four hub bolts from the back of the knuckle and it should pop free with a hammer and some penetrating lube if needed. It helps to remove the outer tie rod end so that you can swing the suspensions forward and back to get to all the bolts.
Generally a hub bearing is easy to diagnos by loading the suspect side of the vehicle up and listening to see if the noise gets worse. So, if its right side bearing, make a some what long hard left turn to load the right side and see if the noise gets worse. If so 99% time it's a wheel bearing/hub.
pirate air is offline   Reply With Quote
Old 09-09-2013, 08:02 PM   #9 (permalink)
Yea and hubs depending on what you get range from $70-180 and the mastercraft hubs are about $260 a hub. They do sell bearings but like pirate said its hard to replace. A new bearing goes for about $40-60
Old 09-10-2013, 08:54 AM   #10 (permalink)
whtrapta's Avatar
Ostrich Wrangler
The truck goes to ford today. ESP is covering the fix. Dealer says it's not a bearing because that would be a constant roar, I have a more pulsing grind. Think of a cricket. It's expected to be something in the 4wd
Engaging 4x4 at speed causes grinding noise! iSurvive Ford Raptor Problems and Questions Forum 32 05-04-2013 02:09 PM
grinding noise near the engine compartment ozzie06 2011 Ford SVT Raptor Forum (Reply Only) 18 12-14-2012 01:36 PM
Hill descent grinding Falcon Ford SVT Raptor General Discussions [GEN 1] 14 06-29-2010 02:58 PM
