Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Remote Start acting up?
This is a discussion on Remote Start acting up? within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Just swapped in a new battery, still an issue...
Like Tree5Likes
Old 02-20-2013, 07:54 PM   #11 (permalink)
Sitdown's Avatar
Sitdown is offline   Reply With Quote
Old 02-20-2013, 08:30 PM   #12 (permalink)
Wilson's Avatar
your talking key fob right
2018 calendar link >http://www.fordraptorforum.com/f16/2...ictures-54101/
Jeff Ethanol I use it
2012 #3105 Diablosport tune aFe stage 2 SW Headers Xpipe true duel S-type muffler 361rwhp
Wilson is offline   Reply With Quote
Old 02-21-2013, 11:21 AM   #13 (permalink)
Sitdown's Avatar
yes fob battery. Guess ill be calling dealer
Old 02-21-2013, 11:24 AM   #14 (permalink)
Wilson's Avatar
that would drive me nuts
Old 02-21-2013, 02:00 PM   #15 (permalink)
NickPic83's Avatar
Ive had a similar issue guys. It could be the truck battery is weak. My battery was shot, almost dead and i went to remote start the truck not knowing and it wouldnt even try to crank. I then used the key and it fired up but i could tell the battery was a little weak. The remote start must have a voltage sensor and if its below a certain voltage it wont try to crank....? This is most likely why it wont start on colder days.
Sent from my DROID RAZR using Tapatalk 2
I.B.E.W. L.U. 363 Journeyman Foreman Electrician
2012 Silver Screw Saints Offroad Front Bumper, mid perch, Retrofits 3" FXR w/ Evil Eyes, SW long tube headers, lightning style exhaust, 5 Star Tunes on SCT Livewire TS, Injen CAI, Method DS black w/ machned lip, lots of LED lights, LED tails, Hornblasters kit, WSI springs, RPG PSR w/cooler & filter, etc...
NickPic83 is offline   Reply With Quote
Old 02-21-2013, 02:50 PM   #16 (permalink)
Blind1's Avatar
It happens to me every once in a while. I found that most of us continue to press the unlock and then 2X repeately & horns goes off twice. Next time it happens to you, press unlock first, and then press the Lock & Remote start button twice. I have noticed that has worked everytime for me.
Also ensure the button under the hood is not stuck in the open position or loose. Good Luck
LineX Premium & Rear Wheel Wells|55" UWS Wedge Tool w/ HiLift Jack Mounted| Stubby Antenna| K&N Filter| Husky Underseat Cargo Liner| 20" M&R LED |SDHQ ABS Guards| DZ Tailgate Assist| Onboard Viair 450C AC| Cargo Rail Sys| Stock Exhaust w/turndowns| SDHQ Frame Reinforcement Kit| Outlaw Shock Guards| Mid Perch|ADD Venom Front w/20" Rigid LED Bar & Rear w/Rigid Duallys - Bumpers| Method NVs 17" w/stock BFGs
Blind1 is offline   Reply With Quote
Old 02-21-2013, 04:21 PM   #17 (permalink)
Sitdown's Avatar
Think my problem may be result of a faulty hood switch. I am now noticing i get a double honk when locking the truck. Found elsewhere that may indicate a door/hood is open when trying to lock it.
Wilson likes this.
Old 02-21-2013, 04:26 PM   #18 (permalink)
Blind1's Avatar
That's usually the case. I found the majority of the folks we have helped in the past had a loose hood switch.
Old 02-21-2013, 04:39 PM   #19 (permalink)
Sliver Raptor's Avatar
That happened once to me but I just unhooked the batt and rehooked it up and it started just fine which makes no sense. Think they can just be a little touchy under the right conditions dunno... Only had that issue once though.
Sliver Raptor is offline   Reply With Quote
Old 02-21-2013, 04:43 PM   #20 (permalink)
BigJ's Avatar
+1 on the hood switch. Can't speak for the Ford system, but if its like others I've used in the past, there's a mercury switch somewhere that disables the system if it thinks the hood is open. Take that switch out of the loop (bypass it) and most remote start issues go away.
Blind1 likes this.
BigJ is offline   Reply With Quote
Tags
electrical, issue, problem, remote, start
Remote Start Raptoyd11 Ford Raptor Problems and Questions Forum 50 01-21-2013 07:57 AM
remote start lockman Ford Raptor Audio/Video/Electronics Forum [GEN 1] 25 10-22-2012 07:57 AM
Remote Start preceptor Ford SVT Raptor General Discussions [GEN 1] 10 05-20-2011 11:28 PM
remote start mrpork Ford Raptor Audio/Video/Electronics Forum [GEN 1] 8 02-04-2011 05:24 AM
Remote start kit The Tank Ford SVT Raptor General Discussions [GEN 1] 11 12-14-2010 03:38 PM
