Ford Raptor Mechanical Problems and Questions Forum Remote Start
This is a discussion on Remote Start within the Ford Raptor Mechanical Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category! Register to remove these ads. It's free!
Don't know what the time limit is but its there. You can only ...
3Likes
02-02-2012, 08:29 AM
#21 (permalink)
Don't know what the time limit is but its there. You can only start it twice in a session. Third time it will just honk at you.
02-02-2012, 09:06 AM
#22 (permalink)
I believe it is limited to twice per hour...
04-23-2012, 10:32 AM
#23 (permalink)
Full Throttle Member
I think there is more to this than a time limit issue or operator error. I have this intermittent problem as well. I tried to remote start my truck this morning from inside my house as I was getting ready for work - the exact same thing I do every morning, and I got the honk. The truck has been sitting all night. I just got the single honk and I had to start it manually. After that, remote start will work fine for a while. I have found no rhyme or reason. It appears totally random to me. I can say for SURE that remote start IS on. My key has been programmed, and I hadn't used the remote start in at least 12 hours. There is nothing wrong with the hood sensor - I haven't even opened the hood in some time and usually remote start works no problem. There are too many of us with this same issue for it to be a fluke.
2012 Black Tuxedo Black SuperCrew Raptor
2001 Suzuki GSX-R1000
2008 Mercedes SLK 280
2003 Jeep Rubicon
04-23-2012, 10:39 AM
#24 (permalink)
I agree with you. I get the same problems sometimes.
Originally Posted by BIRDMAN
You both want a Stubby? I've been drinking and feeling generous
Sent from my DROID X2 using Tapatalk 2
2011 Blue Flame Mettalic SVT RAPTOR: 6.2L
Mods: Borla Stinger Cat-Back, 6K HID's, SVT Liscense plate frames, SVT trailer hitch reciever, Line-X bed, Line-X Undercoating, Clear 3M front Guard (Bra), Weather Tech Floor matts All around, L.E.D. Bulbs (Mirrors,Liscense plate, reverse, map,dome,cargo),EL Glow SVT in Blue, DBS Screen, EZDOWN,Craven Speed
04-23-2012, 10:46 AM
#25 (permalink)
Double check your hood to verify it's fully closed. I had the issue a few weeks ago and then I noticed my hood latch was not fully engaged.
2011 Raptor Screw, Lux w/Nav, Tow, LineX Bedliner & Rear Wheel Wells, 55" UWS Wedge w/Notch Tool & HiLift Jack Mounted, Stubby Antenna, K&N drop in Filter, Husky Underseat Cargo Liner, 20" M&R LED Light bar, SDHQ ABS Guards, DZ Tailgate Assist, Onboard Viair 450C Air Compressor, Cargo Rail System, Stock Exhaust w/turndowns, & SDHQ Frame Reinforcement Kit
04-23-2012, 11:04 AM
#26 (permalink)
dont have any issue on mine. Try Lock + start start (its on the key) after the truck is started then unlock the doors.
04-23-2012, 11:55 AM
#27 (permalink)
Check the hood switch (driver side, under the hood, next to the coolant overflow resevoir. May need to bend it up a tad so that it makes better contact. I've had mine off a couple times fiddling with the intake and that's what I've noticed.
Matt
"Everything should be made as simple as possible, but not simpler." -- AE
2011 Tux Black SCREW Loaded - #5173 out of 11135
04-23-2012, 12:28 PM
#28 (permalink)
Once again I'll restate. There is no issue with the hood switch. I can have this problem (on occasion) then start the truck and stop it. Problem will be gone for days or weeks - every time. I don't open my hood. I haven't fiddled with anything under there. I'm 110% confident my hood is fully closed.
This is not a problem with the physical hood or hood switch. I don't see how it can be if I can have the problem, physically start the truck, shut it off without moving it, driving it, doing anything with it - then have remote start work just fine.
2003 Jeep Rubicon
04-23-2012, 12:33 PM
#29 (permalink)
Cool. Just making sure you checked it as I've seen the problems on my truck related to the switch. Hope you figure it out....or the dealer does.
Matt
04-24-2012, 12:19 AM
#30 (permalink)
Agreed Dane
| Thread Tools |
| Display Modes |
Linear Mode
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Remote start...
aarons419 |
Ford Raptor Forum General Discussions |
43 |
11-29-2011 08:21 PM |
Remote start
MBFan |
Prospective Raptor Owners |
13 |
04-22-2011 01:32 PM |
remote start
mrpork |
Ford Raptor Audio/Video/Electronics Forum |
8 |
02-04-2011 04:24 AM |
Remote start kit
The Tank |
11 |
12-14-2010 02:38 PM |
Remote Start
KaiserM715 |
2 |
06-09-2010 09:22 PM |
