Rear End Binding Up When Slowing Down or Taking Off Slow
Xjrguy
I have this issue and I have read that the skip yolk needs to get greased/lubricated.
Have read that Ford trucks have had this issue for a while and it's a well known problem.
I've been in Brian's truck and his has the same issue as mine.
Has anyone here resolved this?
It basically feels like a subtle vibration in the rear of the truck when slowing down to 5MPH or for a stop light.
BIRDMAN
Birdministrator
Boston
you sure it's not the shudder you get from the torque converter? mine humps its way along when i let off the gas.
X
Xjrguy
That's a good point, but based on my (limited) research on this the symptoms I have pretty much parallel other F150 owners who needed to have the slip yolk re-lubed. It's just a nuisance and I've read the problem comes back anyway.
Guess I will live with it.
bstoner59
does it come in shmedium?
Orange, CA
I still think the shudder you felt in my rear was the Nitto MTs I have on. My rear was smooth before I put those big rubbers on.
X
Xjrguy
I'll have to let you drive my truck.
It has the same sensation yours did when slowing down and I have stock tires.
I've read that grit or sand can get into the slip yolk and cause binding up.
I'll see if I can find the TSB or article that describes it better.
If someone didn't know better this is turning out to be one of the gayest threads ever in regards to the vocabulary words used here. HAHAHA. Getting a good laugh over it.
