Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Please help
This is a discussion on Please help within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
I have an ADD Stealth Winch bumper. I also have a Roush supercharger. The superchargers cooler is interfering with mounting ...
Old 11-15-2012, 10:02 AM   #1 (permalink)
Dan06's Avatar
Default Please help
I have an ADD Stealth Winch bumper. I also have a Roush supercharger. The superchargers cooler is interfering with mounting the winch. The winch is a Recon 10.5. Has anyone dealt with this problem?
PLEASE HELP! Thanks for any input
Dan06 is offline   Reply With Quote
Old 11-20-2012, 05:35 PM   #2 (permalink)
c-ne-elk's Avatar
While I do not/did not have a supercharger, the way my ADD bumper came from ADD I could not mount my winch. The winch sat too far back and was hitting the condensing unit. But I did have plenty of room to move the winch forward and still have it work.
So I took the bumper off, welded a new plate betweent the existing plate and the back of the bumper, drilled new holes and remounted the bumper then installed the winch. (you have to have the bumper on before you mount the winch)
If you do this, a word of caution, watch the angle that your winch gets to. Make sure that your cable/rope from your winch will not fit through the fairlead without rubbing anything else. Mine cleared fine but not by much.
If yours is like mine, there is plenty of room to move the winch forward (toward the bumper) is there?
12 ScrewlLux PacklNavlMrooflStage 3lmid perchlLinex bed/fenderlrollnloc lbedrug matltailgate matl underseat lock boxl Mirror reflector deletelRPG PS ReslWarn 9.5 CTI lVenom front lDimp R rear w/ Rigid D2"slRigid 40" behind grill light barl W. techl CS Stubby l5 Star X3 Tune lAFE Stage 2lRaptor Retrofit MH-1 w/ LED Rings lMethod Double Standards
c-ne-elk is offline   Reply With Quote
Tags
addictive desert design, bumper, recon, supercharger, winch
