Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
P0720 Code... Output Speed Shaft Sensor How to DIY?
This is a discussion on P0720 Code... Output Speed Shaft Sensor How to DIY? within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
So I have a transmission issue and have retrieved a code "P0720 Fault in the Output Speed Sensor electrical circuit ...
Old 12-09-2015, 07:32 PM   #1 (permalink)
whoisbigman's Avatar
Default P0720 Code... Output Speed Shaft Sensor How to DIY?
So I have a transmission issue and have retrieved a code "P0720 Fault in the Output Speed Sensor electrical circuit for a predetermined period of time."
The transmission has been acting up... shifting up to 5th while stopped and won't shift down in drive or manual. It's been doing this 1 or 2 times a day and is fixed by stopping, shifting to R and then back to D.
Then today, truck shifted to 5th while taking off, big wrench on dash, odometer read just lines, no speedometer, and truck only limping between 3rd and 5th gear. This happened once in the past and reset when key turned off and restarted... no persistent code was left that incident. Today I limped to Ford and showed service guy who said nobody was available to pull a code and told me to leave it. I explained that code would be gone and that turning truck off would temporarily remedy the problem knowing that they won't be able to reproduce issue. He looked at dash and moved transmission to observe and made notes and appointment for Friday. I limped over to AutoZone and they pulled the code. i shut the truck off, restarted, and all normal.
Now the question part of my litany of woe... I see the TSB 13-6-8 June 7, 2013... Is this something I can do myself? Is this just a part inside the tranny pan that I can access with regular mechanic tools in my garage (interpret term "mechanic" loosely)? Should anything else be replaced...wiring harness, plugs??? What is a "Output Shaft Speed Sensor"?
2012 Tux Black, Loaded. Previous owner added Spray-in liner, bed cover, LED everything, AFE intake, Magnaflow Exhaust, mid-perch... other stuff I haven't found yet. Thank You whoever you are... I have added 37" Nitto tires, painted speaker grilles, Roush vacuum gauge for hubs.
whoisbigman is offline   Reply With Quote
Old 12-10-2015, 12:33 PM   #2 (permalink)
cups's Avatar
I don't know. Dealer charged me about $800 to drop the trans and replace a harness. Now two weeks later it's start again. I'll have to bring it back in for more.
cups is offline   Reply With Quote
Old 12-14-2015, 06:19 PM   #3 (permalink)
Took it to the dealership, fixed under warranty according to TSB.
Speed sensor replacement questions ngc414 Ford Raptor Problems and Questions Forum 3 12-14-2015 04:55 PM
Vehicle Speed Sensor SVT 4x4 Ford Raptor Problems and Questions Forum 2 10-12-2014 05:26 PM
Freak Accident or Weakness Found? Wheel Speed Sensor... BigJ Ford SVT Raptor General Discussions [GEN 1] 70 08-28-2014 11:20 AM
Code P0720 , limp mode , shifting problems Bavarian Ford Raptor Problems and Questions Forum 1 02-21-2014 07:55 PM
ADD Wheel Speed Sensor Shields Installed (with pics!) BigJ Ford SVT Raptor General Discussions [GEN 1] 6 01-24-2014 05:46 PM
