The Tank
If you have any VCT or Ti-VCT the tick you hear is one of the cam phasers. Ford has several TSBs across several models of vehicles about this problem.
If you have an Ecoboost engine the noise you is from your fuel injectors. Because of the extremely high fuel pressure that the injectors fire at it sounds like a tick but its normal. Also all Ecoboost engines are Ti-VCT.
IN EITHER CASE BRING YOUR VEHICLE TO THE DEALER. DO NOT ASSUME THE NOISE IS NORMAL UNTIL THE DEALER SHOWS YOU SOMETHING FROM FORD SAYING IT IS. FORD DOES NOT KNOW ABOUT PROBLEMS ESPECIALLY NOISE ISSUES UNTIL THEY START SEEING A PATTERN AT THE DEALER.
Can a mod sticky this.
