GEN 1 Need some help
Humvee21
Can someone go out to their truck and check a couple things for me?
1. Where lower splash guard in front of the radiator clip to? Is it to the stock bumper or lower valance? The body shop just left it hanging in there....
2. Is there supposed to be a splash guard on the passenger side fender in front of the tire? I have one on the driver's side.
3. Is there a P/N on the bolt that goes through the lower valance and bumper bracket? Or bolt size?
Deleted member 12951
1. It went to the stock bumper. Just get some zip ties and tie it up. Some just remove the whole thing. I choose to keep it.
2. Just the driver side has it because of the air filter box. As you can see on mine, its been ripped off. Probably off-roading, lol as I just noticed this.
3. Not sure what you are talking about. I got hold of a set of ADD brackets and used those to support the valance. Not sure what looking at on your picture
brc misfit
nor cal
I've got nothing on the passenger side. May be missing due to trails since the drivers side is completely trashed and resting on the skid. Like the ziptie idea.
Humvee21
Humvee21
@RDFTS Rick there's just one bolt to the valance right? Basically the LEX bumper already has that bracket you bought built into the bumper, but the body shop didn't bolt it in. Do you know what bolt size you used?
And thanks for your help! Zip tie idea is great!
McGrath4u
Splash guard connected to stock bumper. I need to hang mine up.
For the valence I used a 1/4"x20x1" long bolt, two washers sandwiching the valence, and a lock nut. Be sure to use stainless.
