My wet Roush Raptor
srs
Tomball, TX
The damage is not that bad. I drowned mine as well. Rookie had the same experience (I believe his was worse). I had about 1' of water in the cab. Damage was the BCM (body control module, fuse box on the passenger kick panel), ACM (audio control module, under the center console), ACM (airbag control module, under center console), battery toasted. I immediately took the entire interior of the truck apart and washed and dried in the next 24 hours. Total bill was about $2,500 in parts.
Ford Service should come back to you stating that not that much damage is done.
Yukon Joe
Russellville, AR
Every electrical component would have to be replaced in my mind. And like @srs said, the interior torn out, cleaned and dried right away. I bet it's just sitting at the dealer getting moldy.
Look up the thread started by @Rookie on his saga to have his swamped raptor fixed. There is some sage advice in the thread and things to watch for if you do decide to fix it.
Best of luck.
Yukon Joe :baby: :baby:
H O L I D A Y CHEER Event fundraiser
Donate $10 for a chance to win a 50" light bar.
http://www.fordraptorforum.com/showthread.php?p=929496
oh, and if you have time, Submit your photo for the calendar contest
http://www.fordraptorforum.com/showthread.php?t=44744
Jimbo
Mad Frog Mattis
IL
FYI - I've dealt with too many insurance flood jobs. I now strongly urge people to cut their losses and let them total it, instead of fighting it. Here in IL, if the water enters the interior cabin, it's considered a total - clearly the insurance companies are sick of dealing with them too.
cbcgeneral
Southeast Pennsylvania
And your point is?
I should have elaborated that he had a similar experience with a water logged Raptor and I tagged him so he would tell you to run away from it as fast as you can not that I was called you a rookie.
---------- Post added at 10:25 AM ---------- Previous post was at 10:24 AM ----------
Here is a link to Rookie's experience with his drowned Raptor:
http://www.fordraptorforum.com/f5/story-mobilebeats-rookie-35284/
Thanks it was late and I just didn't have the energy to find it a post the link so I took the lazy way out lol n
Rookie
Fort Wayne, IN
I feel you should really listen to what I'm about to say. Take the check and run. If they have even hinted at a total loss then you should do it. YOU WILL BE CHASING PROBLEMS FROM THIS FOR YEARS AFTER THEY "FIX" IT, and that's if they do everything PERFECTLY. Throw in the 20 year old tech working on it who smoked a bowl before coming back from lunch, you might as well start crying now.
Don't forget about resale value with a potentially negative vehicle history report. Luckily, mine didn't show anything from the incident. I kept it for a while. Issues popping up occasionally or finding something wrong whenever I worked on it. Sold it to some poor sap who has had some issues with it since.
Read through my above linked thread and you will understand the nightmare I went through. Primarily due to a ****** dealer but I'm not sure how you determine which one you could rely on. Your truck will never be the same.
L
Thanks to all for your responses. Knowledge is power.. i'm certainly more informed than I was 24 hours ago. I'm obviously in the early stages of my ordeal but I will post my progress as things progress.
---------- Post added at 11:51 PM ---------- Previous post was at 11:46 PM ----------
I hope the poor sap you sold it to want a close friend or relative! j/k
Thanks for your time in replying and providing other resources to consider..
In humor though, a mostly ok 2014 roush raptor will still kick the shit out of anything else out there.. :)
---------- Post added at 11:54 PM ---------- Previous post was at 11:51 PM ----------
Not at all and thank you. The fact that i am a rookie had more to do with it I'm sure.
cayenne
Windsor, CO
I think your logic is correct as my truck is sure worht 50+k and another 12-15 for the Roush add on.
I'll be curious to see what they say about the Roush. I have a 2014 Roush SE and I've often heard that the Roush addition, even when purchased from a dealer is worth pennies on the dollar.
