PaloAltoLawyer
- Joined
- Jul 30, 2017
- Posts
- 15
- Reaction score
- 8
Hi All:
Checking in to see if anyone else has this problem. My 2014 Ford Raptor SCREW's left turn signal occasionally (and increasingly often) blinks too fast. All lights on the left turn signal (front, rear and side mirror) all blink too fast when this happens. It's about 2x+ the normal pace.
The thing is that it only does it sometimes. A few weeks ago it would happen generally the first few minutes after startup then stop. Most of the time it would not happen again until I turned off the vehicle, but occasionally it would pop up for a few turns then go away again in the same drive.
Then for the next week or so it never happened at all in any drive. Then three days ago it started happening again intermittently. And since last night it basically happens all the time and hasn't returned to normal pace during a drive as it normally did.
I already walked around the truck with the signal on (both when its acting normally and when its too fast) and all blinker lights are lighting up. I only tried the left turn signal rights when doing this method though (i.e., I did not look at the right turn signal lights).
Has anyone had this happen or know of a solution to try?
Thanks in advance!
Thanks in advance!
