Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Idle fluctuations
This is a discussion on Idle fluctuations within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
I recently added MBRP cat back (no resonator) and AFE air intake. (I will add pics soon) Since that time ...
Like Tree2Likes
  • 1 Post By waddellw
  • 1 Post By LXCoupe
Old 08-10-2017, 08:23 AM   #1 (permalink)
Default Idle fluctuations
I recently added MBRP cat back (no resonator) and AFE air intake. (I will add pics soon) Since that time my idle will act up a little. While at a traffic light it will bounce around dipping down to 600 then up to almost 1000. Also when pulling into my driveway, i left off the throttle but it increased in RPM. Also, the downshift. Not sure if it did it before and I didn't notice, but it does it for sure now and I notice. Not sure if the two are related.
I also recently changed spark plugs.
Any ideas what is causing this? I ordered a tuner from 5 star but have not yet received my custom tunes. Hoping this will fix, but wanted to see what FRF community input was.
Thanks,
40oz is offline   Reply With Quote
Old 08-10-2017, 08:37 AM   #2 (permalink)
waddellw's Avatar
Thanks,
Did you remount the MAF perfectly? Those can be quite tricky. It could possibly be the source of your strange idle, but most likely the truck is sorting out the new parts. I'd suggest checking the MAF and disconnecting the battery cable for 10 minutes or so, which should cause the truck to "relearn" certain parameters. This will in theory do what the tune would do to solve this issue as the tune makes the system relearn also.
40oz likes this.
waddellw is offline   Reply With Quote
Old 08-10-2017, 09:31 AM   #3 (permalink)
I will give that a try. I did not disconnect the MAF just removed the two screws and made the swap. I took my time and did not touch the actual MAF while changing just the base.
Old 08-10-2017, 11:06 AM   #4 (permalink)
LXCoupe's Avatar
I had the same problem on my ecoboost F150. Do as waddellw mentioned. Disconnect the battery (I did it over night). Start it up and let it idle for about 10 minutes. It'll idle rough at first but eventually even out. It might also drive erratic too after this, because you also cleared the fuel map for driving. It should level out after a couple minutes of normal driving.
40oz likes this.
2013 Terain Raptor Screw / 18x9 Method NV / BFG KO2 35-12.5/18 / MBRP 3.5in Black Catback
LXCoupe is offline   Reply With Quote
Old 08-11-2017, 12:30 PM   #5 (permalink)
Update - Received my tunes from 5 star tuning and uploaded to truck. The first ride after that was a little shaky, but today on the way to work it seemed better. Then drove again to run some errands and seems to be clearing up. Still have a high idle and slow to return to 600 when approaching a stoplight but will continue to monitor. Thanks for the feedback.
GEN 2 Shudder at Idle with AC on. dinoone Ford Raptor Engine Discussion and Performance Mods - 3.5 Liter EcoBoost V6 [GEN 2] 181 07-27-2017 03:52 PM
Idle issue? Bulletnjm 5 Star Tuning 26 06-30-2016 09:15 PM
weird idle.... ossachuk Ford Raptor Problems and Questions Forum 4 02-24-2015 09:42 AM
How smooth is your idle? Hoverp Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 26 08-19-2014 03:18 PM
Idle Issue RaptorSpartan Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 8 03-05-2013 09:11 PM
