Houston we have a problem! (the bent frame thread)
SPRSNK
I Void Warranties
Franklin, TN
I'm not sure if you posted it but what did you end up doing to your truck to prepare for the next run?
New A arm, bushings, welded the crack, alignment, 1" uniball upper control arm, heim tie rod, Lowrance GPS, ICOM Chase Radio, drive shaft clunk fixed, Vodka in the stainless steel water bottle, stainless steel brake lines (if I remember to bring them this time) and my GoPro's mounted inside the truck so everyone can hear my sister screaming and my maniacal laughter.
IRONMAN
Well-Known Member
MICHIGAN
YES! Very important.:peace:
gotSVT
SoIL
Could you guys just make a deal with eachother to never speak of what carnage happens? Only to be shared with members through pm's? Thaaaaanks.:birgits_tiredcoffee
If we kept it a secret what would all the keyboard jockeys with their street Raptors (if they have one at all) have to talk about? I figure it is community service.
GRT4DRT
Well said my friend! Gotta feed the trollz....
bstoner59
does it come in shmedium?
Orange, CA
This was posted by BlueSVT on ****** in the Outlaw Run thread...
"The guys that didn't finish either quit early, or had mechanical issues. It was by no means a walk in the park, although there is NO reason you couldn't do the entire run at a moderate pace without any damage or issues... It all depends on the driver"
I thought it was Fords problem that the frame bent and it has nothing to do with driver error??? I'm confused now... This guy is a complete tool!
