ThatGuy88
so I just got my truck back from the retards at the body shop and it is worse than when i brought it in but regardless. I just got back from ohio (not with the truck) picking up a new cooler line that they biffed up. the next main hurdle is the computer and idle issue. The truck displays hill decent control fault, I did not get a chance to check the abs senors or disconnect the battery yet. Also i have two DTC's in the computer P0103 and P0113. Now the truck does have a S&B intake and a SVC tune. I did return in to stock but no change. I did not have a chance to put miles on it for it to relearn everything since the tranny would overheat. the last thing is I am pretty sure the a** clown at the body shop eithered the motor which is a big no no for new motors, sensors, etc.
I would just like some help and any other areas to investigate this weekened while I work on her.
