I had a bad actuator in the dash. The passenger side would heat up but the driver side vents would stay cool. Is this what yours is doing?
I’m having this exact issue. Any insight on how to fix it as I’m out of warranty and it sounds like a fairly simple fixI had a bad actuator in the dash. The passenger side would heat up but the driver side vents would stay cool. Is this what yours is doing?
It's not the easy one to do, you have to remove parts of the dash, lots of videos on this. The actuator is cheap though. The easy one that takes 10 minutes to change is just above the gas pedal and that controls the airflow from the vents to the defrost to the floor, the other 2 actuators are hidden in the dash, if you dont have girlie arms and fingers you will be cursing, lol.I’m having this exact issue. Any insight on how to fix it as I’m out of warranty and it sounds like a fairly simple fix
Any suggestions on videos? All I can find are the 2010-2016 models and I believe the one I need is the one right above the gas pedal which is a plus since it’s just my drivers side and dash vents like you stated. Plus I am fortunate to have those girlie arms you speak of so I may have a chance to test em outIt's not the easy one to do, you have to remove parts of the dash, lots of videos on this. The actuator is cheap though. The easy one that takes 10 minutes to change is just above the gas pedal and that controls the airflow from the vents to the defrost to the floor, the other 2 actuators are hidden in the dash, if you dont have girlie arms and fingers you will be cursing, lol.
No, that one controls all of the vents, it diverts all of the air from either defrost, to the floor or out of the vents. The other actuators fluctuate between left and right, etc, I will look for the video of the one you need, hang on.Any suggestions on videos? All I can find are the 2010-2016 models and I believe the one I need is the one right above the gas pedal which is a plus since it’s just my drivers side and dash vents like you stated. Plus I am fortunate to have those girlie arms you speak of so I may have a chance to test em out
Thank you kind sir! My girlie arms and myself appreciate your efforts lolNo, that one controls all of the vents, it diverts all of the air from either defrost, to the floor or out of the vents. The other actuators fluctuate between left and right, etc, I will look for the video of the one you need, hang on.
