Heat not working on passenger side
lbrewster4
Just hoping to get a little insight on what the problem is before i tear the dash apart to replace the blend door motor. I have dual climate control and the passenger side only blows cold air no matter the temperature settings and if it is floor, defrost, or any other settings. I have read it can be the blend door or the control module for it. Anyone else had this problem?
HORN HIGH ACES
Colorado
Yeah, but that broke the air recirc for the A/C and the heater worked properly last winter. I guess I'll get 2 birds when I get it fixed.
Speaking of which...when is the next time you'll be in CO. ;)
B E N
Frederick, CO
The passenger side blend door actuator can be done in about a half hour, you don't need to pull the entire dash apart. I don't know if there are rules on posting to other forums but there is a hack for it just search the interwebs.
