Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Fuel Fill Inlet
This is a discussion on Fuel Fill Inlet within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Old 03-19-2017, 06:31 PM   #1 (permalink)
SZDZMTR's Avatar
Default Fuel Fill Inlet
The other day, i turned on the truck as usual, and as soon as it fired up the Message "check fuel fill inlet" came up. Wtf. Googled the problem, suggestions are to spray a little bit of WD40 and stick the plastic filler tube in and out multiple times. did this procedure a couple of times….the warning light still comes up. any other suggestions?
2013 SCREW TUX BLACK LOADED (MONEY PIT)
2011 SCAB MOLTEN ORANGE (SOLD)
SZDZMTR is offline   Reply With Quote
Old 03-20-2017, 01:57 PM   #2 (permalink)
SZDZMTR's Avatar
Crickets......
Old 03-20-2017, 02:08 PM   #3 (permalink)
EricM's Avatar
It's the new check gas cap warning- your shit isn't sealing up right so it's failing the self test. Might just need to replace the filler neck/assembly. I don't think it's all that difficult to replace.
2013 Tux Black SuperCrew.
Nobody gives a crap where your post was sent from...
EricM is offline   Reply With Quote
Old 03-20-2017, 02:20 PM   #4 (permalink)
2014RubyRed's Avatar
Even after you correct the issue, the indicator will still light up until it resets.
2014RubyRed is offline   Reply With Quote
Old 03-20-2017, 02:27 PM   #5 (permalink)
Fred's Avatar
unplug the negative cable on the battery for 30 minutes and see if the issue comes back..
Fred is offline   Reply With Quote
Old 03-20-2017, 02:35 PM   #6 (permalink)
I think it actually works off of key starts. Mine did it once and I did the WD40 thing. Took about 3-4 days to finally reset. Warning lights drive me nuts though, so I feel your pain......
Old 03-20-2017, 06:17 PM   #7 (permalink)
SZDZMTR's Avatar
Thanks for the input. I realize its just a bullshit issue. Will try disconnecting battery and may be ordering new filler neck. Cleaned the shit out of the inlet...brining scanner tonight will check and reset the code. Thank you again guys.
GEN 1 Fuel Fill Inlet Mjparsons Ford SVT Raptor General Discussions [GEN 1] 1 10-17-2016 11:50 PM
2.5 inlet vs 3 in Gsteve Ford Raptor Exhaust and Cutouts Discussion [GEN 1] 4 04-07-2015 12:01 AM
S&B air box inlet Hoverp Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 8 01-07-2015 12:09 AM
Dripping paint from gas inlet on new 2014 BAMFTX 2014 Ford SVT Raptor Forum (Reply Only) 10 01-21-2014 05:44 PM
Check fuel filler inlet delmag1942 Ford Raptor Problems and Questions Forum 1 09-06-2012 10:20 AM
