Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Fuel Blockage
This is a discussion on Fuel Blockage within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Raptor would not turn over last night, Must of tried 12 times, extended cranking, no fuel. NOT DTCs or extended ...
Old 01-10-2014, 07:26 PM   #1 (permalink)
E63's Avatar
E63
Default Fuel Blockage
Raptor would not turn over last night, Must of tried 12 times, extended cranking, no fuel. NOT DTCs or extended DTCs. I was on perfectly flat under ground parking, 3/4 of tank of gas.
Got a great tip to tap the gas tank with a hammer while cranking. Worked like a charm. So is the problem a stuck float? Dirt in the intake? IDK I also don't know if I need to do anything or if it is was a one time thing. Knowing how to fix makes me feel a lot better about it, but this was the first time my Raptor ever stranded me. Took 2.5 hours to get sorted out.
I am in the dirt all the time, and I clean out the inside of the filler neck every time I wash the beast. Frankly the easy fill is probably not a good idea for those of us who off road all the time in the dry dirt.
Visit my Build Thread: http://www.fordraptorforum.com/f65/gs-raptor-14639/
2012 Raptor SCREW - White, Ordered 8-31, built 2-6-12, Arrived 3/13/12
E63 is offline   Reply With Quote
Old 01-10-2014, 07:39 PM   #2 (permalink)
bcjohnson22's Avatar
Wow. It'll be interesting to hear if it happens again.. hopefully it doesn't.
Rural Missouri
bcjohnson22 is offline   Reply With Quote
Old 01-10-2014, 09:24 PM   #3 (permalink)
pat'sRAPTOR's Avatar
they do make a locking cover for the filler neck so no one can siphon your fuel and im sure itll help keep dirt out
pat'sRAPTOR is offline   Reply With Quote
Old 01-10-2014, 09:35 PM   #4 (permalink)
WRCRaptor's Avatar
That is not good. You clould use the remote start and hammer trick if you are alone. I bought the locking gas cap to keep the salty slush (winter) dust & mud (summer) not really for the security aspect. Works very well.
Fuel contamination maybe?
WRCRaptor is offline   Reply With Quote
Old 01-10-2014, 09:50 PM   #5 (permalink)
E63's Avatar
E63
Thanks guys,
I hope it doesn't continue, I will likely look into the locking gas cap. The truck has started up just fine last three uses.
Old 01-10-2014, 09:58 PM   #6 (permalink)
maybe it was just a small piece and now its gone hopefully!
Old 01-10-2014, 11:17 PM   #7 (permalink)
SuperRaptor's Avatar
I know that in Chevy's when your fuel pump is going the old trick is to tap it a few times to get it going and get yourself home. Don't know how you could prove to Ford that is what is though.
SuperRaptor is offline   Reply With Quote
Old 01-11-2014, 12:22 AM   #8 (permalink)
Ingot SVT's Avatar
Sounds like a failing fuel pump. The pump portion of the fuel sending unit has a mesh screen that prefilters the fuel going into the pump, would have to be a very very small object in order to get past the screen to then get lodged in the pumps internals. No codes with a no start plus banging on the fuel tank then starts up. points to an intermittent pump failure. I have the locking gas cap just for the fact that it can help eliminate debris from getting into the capless tank system and a small peice of mind that only I open the tank and fill it with gas.
Ingot SVT is offline   Reply With Quote
Tags
blockage, filler neck, fuel
Fuel Cap Leak.. Drift Ford Raptor Problems and Questions Forum 11 05-13-2013 01:50 PM
110 octane fuel?? HAYNES OFFROAD Ford SVT Raptor General Discussions [GEN 1] 4 11-25-2011 07:02 PM
6.2 fuel ? debate Ford Raptor Engine Discussion and Performance Mods-6.2 Liter V8 [GEN 1] 16 09-13-2011 03:17 PM
Fuel Consumption vs. Speed - A semi-scientific study of Raptor Fuel Economy TurboDog Ford SVT Raptor General Discussions [GEN 1] 9 12-07-2010 12:40 AM
