Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
Front tire wear problems
This is a discussion on Front tire wear problems within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Same here. Did it at low perch and it does it now at mid perch....
Old 04-18-2014, 08:16 PM   #11 (permalink)
6point2's Avatar
2012 White Screw | 17" Methods | 35" Nitto Trails |
| Mid Perch | Roush exhaust | Roush Intake |
6point2 is offline   Reply With Quote
Old 04-19-2014, 01:54 AM   #12 (permalink)
McDowell's Avatar
Wtf
Sent from my iPhone
Originally Posted by RDFTS View Post
My balls are small.
This is America. We drink beer, carry guns, say merry christmas, and speak English. If you don't like it get the hell out.
McDowell is offline   Reply With Quote
Old 04-24-2014, 01:32 AM   #13 (permalink)
everyone Ive put on the alignment rack(about 30-40) are toe'd out from the factory.
I lower the air pressure to 30-33 psi and recalibrate the tpms. of course the customer has to agree to this but they are D rated tires they can handle it just fine unless youre going to be at 100mph all day long.
also getting the tires rotated every 3k will help.
sanddunesaddict is offline   Reply With Quote
Old 04-24-2014, 07:07 PM   #14 (permalink)
McDowell's Avatar
Thanks man
Sent from my iPhone
My balls are small.
Old 04-24-2014, 11:30 PM   #15 (permalink)
Baja Jones's Avatar
Everyone is missing this. The truck properly aligned at any ride height will not prematurely wear the tires. A tire sitting flat on the ground with proper toe Wears just fine, provided you are not taking exit ramps at mach II. The factory alignment slots in the frame are a worthless attempt at retaining front end alignment on an off-road vehicle. Just riding a burmed corner to hard will cause lower A arm movement and alignment change. Total Chaos Fabrication is making an eccentric lower control arm bolt with a pair of weld on guides that will not allow the lower A arm to slide when you take a shot to the bottom of the tire. Not on their web site yet but call them and get in line. Do not install the bolt on fix with the eccentric on the nut. The control arm turns the bolt and when they fall off you are screwed. Fixed a couple at TRR 14 one where the lower control arm bolt fell out. Don't let flat rate techs align your vehicle. When you bring it back after 2 weeks and 1500 miles they get charged back. So they give it a sun bath and hand it back to you. Firestone Tire stores have a lifetime alignment package for around $170. They used to cringe when they saw me coming. After the Chaos kit not so much.
Baja Jones is offline   Reply With Quote
Old 04-25-2014, 10:30 PM   #16 (permalink)
McDowell's Avatar
this is very helpful thank you very much!
My balls are small.
Old 04-26-2014, 02:09 PM   #17 (permalink)
ISFast's Avatar
Double and Triple check with what ever Firestone shop you go too! I had a NIGHTMARE come to reality when I went there to get the "lifetime" alignment. Long story short... They had to by me all 4 new wheels and didn't even get the alignment started.
Is that all?
ISFast is offline   Reply With Quote
Old 04-26-2014, 05:15 PM   #18 (permalink)
McDowell's Avatar
Holy shit how did u get that to happen
Sent from my iPhone
My balls are small.
Old 04-26-2014, 05:16 PM   #19 (permalink)
Red's Avatar
Red
I think they scratched up his wheels.
2013 White SCREW...K&N CAI, Magnaflow, 10% Tint, hefty fab skid, whelens with WSI mounts, WSI HD Springs, spray in liner,TMX Skid Plate, 30"LED, Mid Perch, Bed Rack
Red is offline   Reply With Quote
Tags
alignment, tires
Torsen front axle problems ! anyone else ??? ITSALLGOOD Ford Raptor Problems and Questions Forum 302 05-16-2015 10:52 AM
BFG tire wear? warrior Ford Raptor Wheels & Tires Forum [GEN 1] 63 12-02-2013 10:52 PM
If you havin' girl problems I feel bad for you son. I got 99 problems... Humvee21 Other Vehicles 55 11-21-2011 02:08 PM
Common Issues/Wear/Problems? LandSeaAir New Member Check-In 9 12-08-2010 05:08 PM
How to read tire wear SOCOMech Ford Raptor Maintenance Forum 1 03-16-2010 04:32 AM
