DS headlight staying on
JtoU
Having problems with headlight, damn thing stays on no matter where i turn switch. Problem started after wash and i notes at night that headlights go on and off. First i thought that there is water on relay but didn't find anything so i disconnected hid harness for rest of the night. Connected harness in the morning and just DS headlight kept staying on. I got retrofits with hid harness for halogen wiring. Any help appreciated, thanks.
FarFromStock
Chuluota, Florida
Check your grounds. I had the same issue and found that one of the ground wires leading to the ballast wasn't making a good connection.
JtoU
JtoU
Didn't find anything else than this
but not sure it was issue since it was still hanging there. Swapped new one there and will keep eye on does light stay on.
Thank you for the tip.
