Dash Light for Rear Defrost?
navywolf
VA
Hopefully I can get a quick turnaround on this ?
Just need someone to confirm if you push the rear defrost button you get a small amber light.
My truck was used when purchased and nearly everything in the panel lights up when touched except that button.
If it matters I'm a 2014 SCrew.
Thanks
Carsten89
Springfield, MO
Thanks
Yes it should light up. Have you tried opening and shutting the rear sliding window? My button wasn't lighting up either so I checked the window and it wasn't closed all the way. My son must have messed with the button when I wasn't in the truck.
Edit: There should be contacts on the glass too, also make sure the window edges are clean.
N
navywolf
VA
Perfect. Thank you. I'll look into it now that I have a starting point.
I needed to confirm it had a working light at some point.
Carsten89
Springfield, MO
I highly doubt the light is burned out, but you can also try the climate control on the nav screen and see if it lights up.
RaptorEnthusiast
I just had this issue just before Thanksgiving. I had Ford Customer Service contact the dealer to cover the rear defrost window replacement under warranty.
I was told that the contact points of the rear window were not properly engaged, so they just replaced the rear defrost window.
David
N
navywolf
VA
I'll give that a shot as well.
I'm going to have some down time this weekend and plan to install a catch can and figure out the light issue.
Obviously it isn't anything critical to the vehicle, but I like to stay on top of things as much as possible.
Wfo
Syracuse
Common issue. The whole rear window needs to be replaced, ****** design. If you come up with a fix please post as I'm sure many could benefit.
N
navywolf
VA
David
Hmm. I'm still under warranty. May have to have them fix it if it winds up being more than a light.
You wouldn't think a 2 year old truck would have a burned out LED this early in life, but you never know.
---------- Post added at 10:01 AM ---------- Previous post was at 09:59 AM ----------
I'll post up when it's resolved so everyone has closure.
Too much happening until Friday or Saturday for me to get in and play with it.
RaptorEnthusiast
Yeah, I really doubt the amber light indicator has burnt out.
One way to confirm, is see if your rear window defrosts when you press the button.
Either way, from my recent experiences, it appears you will need to have the rear window replaced. It's great that you are under warranty, it will be covered.
David
N
navywolf
VA
Had time to mess with it and the rear defrost officially doesn't work.
Took it to the local dealer who reconfirmed rear defrost doesn't work. They took apart the molding and took a bunch of pictures to prove it was original/undamaged.
Paperwork being submitted to Ford for warranty replacement.
Thank you all for the help.
