firemedic343
- Joined
- Dec 14, 2016
- Posts
- 9
- Reaction score
- 3
I have a 2014 6.2 and the thing has had a gremlin about leaking coolant (among so many other issues) for a while now. It's had the upper hose replaced, the lower hose replaced, the water pump replaced (all the sources of the leaks), and it's still spontaneously popping up. My only theories are that the pressure is getting way too high and causing it to seep out wherever it can. I conclude this based on hose fittings coming loose and when tightened is when the coolant begins to squeeze out where the water pump is sealed against the front of the engine.
Any other thoughts or solutions anyone can add?.
