Hey guys,
Not sure what I should do and was looking for a little advice.
A few days ago my wife was driving home on a rainy night down the highway. She called me to let me know the CHECK ENGINE LIGHT had just turned on. Truck has about 1,200 miles and had about at 3/4 of a tank of 93o from a new fill station I don't normally go to. My stomach turned when she gave me the call and when she got back home I went out and read the manual. This is what the manual has to say.
"When the service engine soon
indicator illuminates, the OBD-II
system has detected a
malfunction. Temporary malfunctions may
cause the service engine soon indicator to
illuminate. Examples are:
1. Your vehicle has run out of fuel
— the engine may misfire or run poorly.
2. Poor fuel quality or water in the fuel
3. The fuel fill inlet may not have closed
properly. See Refueling (page 180).
4. Driving through deep water
— the electrical system may be wet.
You can correct these temporary
malfunctions by filling the fuel tank with
good quality fuel, properly closing the fuel
fill inlet or letting the electrical system dry
out. After three driving cycles without these
or any other temporary malfunctions
present, the service engine soon indicator
should stay off the next time you start the
engine. A driving cycle consists of a cold
engine startup followed by mixed city and
highway driving. No additional vehicle
service is required.
If the service engine soon indicator remains
on, have your vehicle serviced at the first
available opportunity. Although some
malfunctions detected by the OBD-II may
not have symptoms that are apparent,
continued driving with the service engine
soon indicator on can result in increased
emissions, lower fuel economy, reduced
engine and transmission smoothness and
lead to more costly repairs."
After reading this I cycled the engine and the light went away! All was great until last night on my way home when the light came back on. It was also a wet drive on the highway with the same tank of gas. My stomach turned again and I was pissed. I cycled the engine again and the light stayed off again. This is my first Raptor and new vehicle for that matter. I really didn't want to take it back to the dealer because I don't like people messing with my stuff, but might have to. I haven't seen anyone else report this so I figured I'd open up the topic. Any advice on what I should do? Wait and see if a new tank of gas clears up the issue? Hope it never comes back and forget it? See if the dealer can detect if there was a code thrown?
I've seen a couple people suggesting to drill a weep hole in the intercooler to drain the condensation. Haven't looked much into this yet but maybe a possible solution?
10/17 build date
Thanks guys
10/17 build date
Thanks guys
