RaptorSteve
Does anyone know off the top of their head a good chassis ground point under the shifter bezel or under the right side of the dash? Preferably with a screw/bolt already there.
Thanks.
Thanks.
you have to pull the whole center console out. a bit time consuming....
Yeah, I have the shifter bezel out and there's nothing but plastic staring me in the face. I see some wires going up under the dash so I'm going to try and route my wire down and over under the glove box and ground it there. This should't be a "sensitive" install. It's the mode switch for the OnX Led bar. You push it once and it grounds a signal to the bar to change modes Hi Intensity->Half Intensity->Strobe and back with each press.
