I am pretty sure you are all going to direct me to the third brake light but I thought I'd still put it out there to see if anyone else had this same or similar problem and found the actual cause.
Sometimes when I hit the left blinker, either the lane change or full turn, it'll blink really fast like my Jag does if a bulb is out. Sometimes it'll blink fast then go back to normal. Most of the times it blinks normally. I had my wife hit the blinkers a few times in the drive way and sure as shit, when it did blink fast the bottom left turn signal did not light. When it blinked normally, all lights worked as normal.
With the plethora of experience and knowledge on here... what say you?
Thanks for your time.
