Otis857
Can use your help, gang
When I changed my front springs to Gieser Bros, i inadvertently let the axle slide out of the splines in the inner CV joint (drivers side). Took a while but i got it back in and thought i was good to go. WRONG!!!. Went 4 wheeling last weekend, and got a pop from the drivers side in 4x4 only. I thought it was the usual IWE, so I just changed it out. Wrong again, I guess Im just not that lucky.
So I jacked it up off the ground, ran it at idle in 4X, and sure as hell, the inner CV is popping. My question is, does Ford use a clip on the axle splines that just pops off like most front wheel drive cars do to hold the axle shaft into the front diff? I can usually get them out with a heel bar, but this one isnt budging, and I dont want to make a bad situation worse. Soooo, Is there a clip inside the diff holding it on that I have to pull off the cover to get to, or am I just not prying hard enough to pop it out of the front diff?
Also, any front axle where to purchase recommendations?
TIA
TIA
