Backup camera showing front!
jmerwin06
I just brought home a 2012 SCREW last night (yay!!!!) but for some reason when the truck is in reverse, the nav screen shows the view from the front. Very disorienting!!! I'm going to call the dealer on Monday but I was wondering if any of you had this problem and if there is an easy fix for it. Thanks in advance!!
-m
Sent from my iPad using Tapatalk HD
jmerwin06
jmerwin06
Ahhh. I figured that. Had a small hope there was a simple fix. Thanks!
jmerwin06
jmerwin06
Haha! True dat.
---------- Post added at 10:32 AM ---------- Previous post was at 10:26 AM ----------
Mine had that problem. It required a new pcm.
sent from Tapatalk on my HTC View
How long did it take to fix?
Fred
Richmond, VA
Do they not test this stuff before it rolls out the door?
I guess it is cheaper to deal with any issues that may come than making "Quality Job #1"
jmerwin06
jmerwin06
Ikr? Dude told us it was just a setting. After messing with it for an hour and reading tons of forums (that's how I found this site) I decided that it's def not 'just a setting'.
Deleted member 12951
Damn, mine when trying to use the front camera, it shows the reverse camera instead. Doesn't happen every time, only when you really wanted it to work
