"Auto" climate control sporatic
c19dale
Jacksonville FL
I have a 2014 SCREW and it seems the AUTO climate control is working sporadic. Sometimes it works fine when you adjust the temperature up and down, sometimes, you can turn it down to 60deg or LO and there is just a slight cool breeze blowing out the vents when it should be blasting in the FL heat. anyone experience this? I am taking to the dealer soon, but you know how sporadic issues and dealers go if they cant replicate it when I bring it in.
Jimbo
Mad Frog Mattis
IL
Double check the A/C illuminates when you are in AUTO, if not, then you have something more solid to report to the dealer.
mridahodan
I've found that on my 2014, if I use the auto start feature, the AC kicks in and cools it down but when I put the key in, it seems to get messed up. The fan still runs, but doesn't really get cool. I have to turn off the climate control and then back on and things are fine.
cayenne
Windsor, CO
I have the same issue in mine. I've only noticed it now that we are getting hot. It's rather annoying. Sometimes I have to turn climate control off and then back on to get it to work. Seems independent of if I use remote start or not for me.
FordService
I have a 2014 SCREW and it seems the AUTO climate control is working sporadic...
Hey, folks!
Now that the weather is getting warmer, I'm sure you'll want the cabs of your trucks to be nice and cool. If your climate control is acting up like c19dale's, get it in front of your dealership so they can help. Need my assistance? PM me your details and I'll research options. Be sure to include your full name, best daytime phone number, VIN, current mileage, and servicing dealership.
Crystal
I have had the exact same problem! It only happens when I use the remote start feature, and only when the AC kicks in (on hot days).
---------- Post added at 12:22 PM ---------- Previous post was at 12:12 PM ----------
Were you guys able to resolve this?
hagak
I think I may have this issue as well. Cab is warm but not throwing air unless I hit max air.
Nv Guy
Nor Nv
My 2010 does this randomly, done it since new.
I don't have remote start, so it's always with the key. What seems to get it going is I shut the system off, restart it and it seems to work fine until the next random occurrence. I never bothered to take it to the dealer due to the randomness.
FWIW my 2013 Escape does the same thing.....
