Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
abs/brake light/hill descent warning lights going off
This is a discussion on abs/brake light/hill descent warning lights going off within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Anybody else had this issue?. Started it up the other day and after a few minutes of driving the dash ...
Like Tree1Likes
  • 1 Post By All The Way
Old 05-05-2014, 08:58 PM   #1 (permalink)
cubiefan101's Avatar
Default abs/brake light/hill descent warning lights going off
Anybody else had this issue?. Started it up the other day and after a few minutes of driving the dash began to go nuts chiming four times and showing the brake light, abs light and hill decent warning light with it stating to check braking system. Also when throughout these errors it won't allow me to use hill descent or off road mode. Any ideas?
cubiefan101 is offline   Reply With Quote
Old 05-05-2014, 09:12 PM   #2 (permalink)
All The Way's Avatar
third break light or a wheel speed sensor
All The Way is offline   Reply With Quote
Old 05-05-2014, 09:20 PM   #3 (permalink)
Huck's Avatar
^^ what he said. I had it happen with an abs speed sensor go bad. But no abs in the snow is a blast
Icom F5021,RPG Stg 4+ Fox 3.0 coilovers, RPG Tie-rods (modified to camburg hardware), RPG PS reservoir, Camburg 1.25" UCA's , Raptor -Retro fit '13 HIDS, Line-x preminum, Bluewater LED bed lights, Ipad mini navigation. Bubba rope. Rollx, Recon 10.5k winch synth rope, factor 55, SVC Custom acuated tower. Visions 30" xmitter extreme, 35" toyo MT, visionx 6550 spot.
Huck is offline   Reply With Quote
Old 05-05-2014, 09:30 PM   #4 (permalink)
Im thinking abs sensor too. If checked the third brake light and put rtv adhesive around the gasket already so it should be good.
Old 05-05-2014, 09:40 PM   #5 (permalink)
Huck's Avatar
check the rear sensors, they can be easily damaged.
Old 05-06-2014, 01:44 AM   #6 (permalink)
Raptor Embroidery's Avatar
aka Raptor_Al_41
Once you get it fixed (if it is abs) wrap the abs lines and get abs guards from one of our vendors (Sdhq outlaw etc)
www.raptorcustomembroidery.com
Call/text - 256-599-6040 Email - [email protected]
Leather wrapped center consoles, embroidery and laser engraving.
Raptor Embroidery is offline   Reply With Quote
Old 12-23-2014, 09:47 PM   #7 (permalink)
8WOOD's Avatar
Don't want to make a new thread so I thought I'd revive this one.
I just had a rock flip up and cut my ABS wire in half on the rear. I got all the indications previously explained in the first post. I spliced the wires back together and was wondering if there's a trick to clearing the codes? Unplug the battery? Or do I have to have a OBDII tool?
If anyone knows it would be great info. Thanks
***UPDATE***
I figured it out. I don't know how, but I started turning the traction control button on and off and it suddenly said advance trac enable and then everything worked again. It must have auto reset or I pushed the traction button enough times to reset the system.
8WOOD is offline   Reply With Quote
Old 12-24-2014, 12:08 AM   #8 (permalink)
Mine cleared right away. 2010 Scab 6.2
Its fun to unplug one during the winter time.
lka likes this.
Old 08-06-2016, 05:11 PM   #9 (permalink)
Junior Member
Default brake warning light frozen pedal. clears
driving 70 on pa turnpike. 2011 screw. red brake warning comes on. press brake pedal hard as rock no braking! pressed again, felt pulsations like abs. then pedal clears and pushes. normal braking. warning light stays on. got off turnpike. check all wheels and reservoir. all good no leaks. braking normal. stopped vehicle for an hour. warning light cleared on restart. ford dealer reveals no faults or abnormalities. suspect sticking vacuum assist valve which is backed up by abs. drove 500 miles since. no issues. any body experience??
JBronius is offline   Reply With Quote
Old 08-06-2016, 05:37 PM   #10 (permalink)
Yukon Joe's Avatar
Not the same driving experience, but close on low speed.
Turned out to be the wheel speed sensor. Dealer replaced under warranty. Needed to replace the whole hub.
@Yukon Joe
Drive your raptor here!!!!
www.runraptorrun.com
( * Y * )
Post a pic ofyour Raptor here:
https://r.tapatalk.com/shareLink?url...8&share_type=t
Calendar contest August 17
Vote for a pic here: vvvvvvvvvvvv
http://www.fordraptorforum.com/showthread.php?p=1010757
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is online now   Reply With Quote
Brake lights stuck on and hill decent message GRI Ford Raptor Problems and Questions Forum 6 06-04-2016 04:45 PM
Hill Descent Control Fault + Brake lights flickering = 3rd Tail Light Leak? BigJ Ford Raptor Problems and Questions Forum 14 03-06-2014 01:01 PM
Hill Descent Control Fault, even after 3rd brake light. Laguna Ford Raptor Problems and Questions Forum 3 11-23-2012 03:13 PM
Who has used hill descent control yet? The Tank Ford SVT Raptor General Discussions [GEN 1] 8 12-04-2010 01:02 AM
Hill descent grinding Falcon Ford SVT Raptor General Discussions [GEN 1] 14 06-29-2010 02:58 PM
