Deleted member 12951
They are calling mid perch a 4" lift.
That's crazy. They can look at the shock rings difference between them to see it is not 4". Are you on 35" tires?
Problem is your extended warranty has also denied it based on this dealership. Is it a Ford warranty or 3rd party?
Personally I would try a different dealership and if you still run into a road block, I would change them myself. Then go to another dealership to fix the rest of it if doesn't solve the issue with the full IWE replacement
