GitErDunn
2010 6.2L SCAB
The brake light mounted on the cab is leaking into my cab, I've put it off for a bit and then happened to forget about it till I washed my truck and finally decided to look in the back seat and seen a little bit of water again. This isn't covered under my extended warranty apparently, will cost like $500 for parts/labour... Before I spend that money, is there a quick/permanent fix that I could do myself to keep it from leaking? I think I seen a post on here before about it but I can't seem to find it.
