Go Back   FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor > Ford Raptor Forums - General Information > Ford Raptor Problems and Questions Forum
2014 Raptor Transfer Case Issues
This is a discussion on 2014 Raptor Transfer Case Issues within the Ford Raptor Problems and Questions Forum forums, part of the Ford Raptor Forums - General Information category!
Good morning, I was curious if any one else has experienced transfer case issues on the 2014. My truck has ...
Like Tree1Likes
Old 02-17-2016, 07:40 AM   #1 (permalink)
Junior Member
Default 2014 Raptor Transfer Case Issues
Good morning,
I was curious if any one else has experienced transfer case issues on the 2014. My truck has been in the shop for a month as the dealer can not get a ring gear. Very disappointing response from Ford Motor Company as well, as they continue to say we'll follow back up with you in a week as I continue to drive the Focus loaner.
I'm surprised for a relatively new Raptor with 37,000 miles that it takes a month to get a part.
Thoughts?
---------- Post added at 12:40 PM ---------- Previous post was at 12:36 PM ----------
The part number is F5TZ7A153A (Ring Gear).
PropFlyr is offline   Reply With Quote
Old 02-17-2016, 09:02 AM   #2 (permalink)
Yukon Joe's Avatar
Haven't heard of too many issues on the transfer case.
In stead of replacing the gear ring, why don't you ask them for availability of the whole case?
You can also see if Chrystal @FordService can help. Many people have had luck when she gets involved.
Vote for your favorite pic
http://www.fordraptorforum.com/f18/j...ar-vote-46906/
@Yukon Joe
Delta Lead
www.runraptorrun.com
2012 SCREW | NIGHT RAPTOR Revolution Wrap | RPG Stage 4+, Black Tie-rods, Prerunner 1.0 UCA, Steering Res | AMB LED Light Kit | Raptor Retrofit HIDs w/ Amber Ring | Hefty Fabworks Skid Plates | ADD ABS Guard | Recon 10500lb Winch w/ Factor55 | Whelen LEDs | WSI FE Mount | Extang Solidfold | Weathertech Liners | PDP Flaps | TYT9000VHF Radio |
I love Raptorwifey
Yukon Joe is offline   Reply With Quote
Old 02-18-2016, 09:48 AM   #3 (permalink)
FordService's Avatar
Ford Professional
Originally Posted by PropFlyr View Post
Good morning,
I'm surprised for a relatively new Raptor with 37,000 miles that it takes a month to get a part...
Welcome to the forum, PropFlyr; let's see what I can do to make things move a bit more quickly. Send me a private message (PM) with your full name, best daytime phone number, VIN, current mileage, and servicing dealership. I'll dig into this a bit deeper.
Crystal
BigMikeVP likes this.
FORD SERVICE
p: 800.392.FORD
t: @FordService @FordTrucks @Ford
f: facebook.com/FordTrucks facebook.com/Ford
FordService is offline   Reply With Quote
Old 02-18-2016, 08:18 PM   #4 (permalink)
Bar
Good morning,
Thoughts?
What's the issue with your transfer case? Mine's in the shop now. They are ordering parts for it.
Bar is offline   Reply With Quote
Old 02-19-2016, 07:19 PM   #5 (permalink)
Junior Member
The truck would "whine" in 4WH, sounded like the whine of a turbo. After 1 week of replacing various parts and not fixing the issue they found metal in the transfer case oil and found two gears with teeth missing. The ring gear has been on back order for over 3 weeks and I'm told will not see it until end of Feb.
---------- Post added at 12:19 AM ---------- Previous post was at 12:17 AM ----------
What is the issue with yours? What year and how many miles?
Old 02-19-2016, 07:24 PM   #6 (permalink)
Bar
Lol! Same. 2014 with 16k miles. Dumbfuck mechanic (shop foreman, actually) at first dealership said it was normal. Second dealership is great. It's been with them a week, and they expect to finish Tuesday.
Old 01-18-2017, 12:49 PM   #7 (permalink)
rjmcintosh59's Avatar
Junior Member
2014 SE with 36,000 miles. 2H and 4H work fine, went into 4L and worked fine, went to get out of 4L and got stuck in neutral, then ground for about 30 seconds then BANG!! and it went back into 4H... several times, it goes in tomorrow to get fixed and see what is causing the problem in 4L
rjmcintosh59 is offline   Reply With Quote
Old 01-18-2017, 01:52 PM   #8 (permalink)
MTF's Avatar
MTF
I hope you're not driving while switching in and out of low, it's always good practice to come to a complete stop and preferable go into neutral then switch.
I know it's all electronic and all, but I've had 4x4s for 30 years it's just something I learned and stick with. If there is pressure against the gears it will bind and not shift correctly.
Even going into 4 HI I try and come to a stop or at least slow down to 30 or less, and coast with the throttle on and off.
I did it one time on the highway at 60 mph and while the dash said 4x4 HI, It did start making grinding noise when I gave it gas.
Keep in mind I can only launch in 4x4 Hi with my truck to get the full effect of the Supercharger. Unless I want roast tires even in two wheel diff locked.
Whipple 700+ HP 800+ in the works, Oil and Fuel pump upgrades, Custom Deavers +2 Rear Springs, Axle Exchange Driveshaft, Rogue Racing Traction Bars, Hellwig rear sway bar, Pace Edward electric bed cover with remote, Pop & Lock Tail Gate lock, Mud Flaps, Window Rain Guards, EZ Down Tailgate, Bed Rug,
Future Installs: Brembo Brakes 15" Gran Turismo
MTF is offline   Reply With Quote
Old 01-18-2017, 10:02 PM   #9 (permalink)
Junior Member
2014 Raptor will not let you. It makes you get in neutral and slow to 5mph or less.. even then if it is binding it will pause the shift and have you back up or pull forward...pretty idiot proof. And I have had Ford 4x4 trucks since 1976 , so pretty good at changing ranges too
Old 01-23-2017, 09:49 AM   #10 (permalink)
jamanrr's Avatar
The only problem I have ever really experienced has been when the VSC kicks in during 4x4 or 4x2 operation. It makes a weird modulating grinding sound, I am just thinking it is the computer making modulations on the drive train for a big truck. It is bound to make some strange noises.
jamanrr is offline   Reply With Quote
Tags
2014 raptor, ford motor company, poor parts support, transfer case
Raptor Transfer Case Fluid Level? TargetBow Ford Raptor Maintenance Forum 4 12-07-2015 01:19 PM
Blown transfer case??? johndjmix Ford Raptor Problems and Questions Forum 19 10-22-2015 03:51 AM
SVT Transfer case vs Crew cab Acerni Ford SVT Raptor General Discussions [GEN 1] 0 03-30-2015 05:03 AM
Transfer case maybe? Little man Ford Raptor Problems and Questions Forum 14 03-04-2015 11:18 AM
Transfer case being replaced... Steele16 Ford Raptor Problems and Questions Forum 12 11-14-2014 01:17 PM
