2014 raptor engine locked up
Oldschooltoy
California
2014 raptor all stock with 25k miles. Was driving on the freeway. Engine started to miss and engine soon light flashing. Took it to the dealer...they said it has low compression and they are still diagnosing it. Couple of days later they say engine is locked up and they want 600.00 to remove valve cover and oil pan. Just in case it's not covered under warranty. Vehicle still under the bumper to bumper warranty. Oil change always done at 3k-4K with Mobil 1 with ford racing filter. Anybody else had a problem like this??
SaintsFan
Louisiana
Do you have any enemies who could have put a harmful substance into your engine or fuel system?
O
Oldschooltoy
California
Broken valve spring...valve hit piston...needs long block. Covered under warranty
5.4raptor
Same problem
Same here mines in the shop same reason I'm at 98,000 miles. How did yours turn out?
