If you are trying to add your own amp you are going to have to take the signals off the existing sony amp under center console. I couldnt find a way to bypass it and have it work correctly. I fed the signals from that amp into the amp i have under my passenger seat. There is no need for a sound proccessor if done correctly as it pretty much eliminates that auto volume correcting. Made the stereo sound like it should have sount front the factory. However you will need to ditch those factory 6x8's they did not last very long after I added the amp. I run full alpine type r's in my doors and 2 kicker 12's in a custom box under rear seat. Sounds awesome.
