Contact Addictive Desert Designs
Telephone 855-233-8992
480-671-0820
Email [email protected]
Website ADD Offroad - The Authority in Offroad Truck Parts and Accessories
FOR IMMEDIATE RELEASE
July 25, 2013
A.D.D. RAPTOR SUSPENSION PRODUCTS PRICE DROP
The World’s Best Suspension, now at a lower price.
Mesa, AZ, July 25, 2013– A.D.D. in their continued effort to provide the world’s best Raptor Products, has now dropped the prices on their best suspension items and added Fox Racing Shocks as an option. Due to the better pricing they are getting with their volume on these components, they are passing this on to their customers.
The price change will decrease the Stage 1 Front Suspension from $2600 to $1699.99 and the Rear Frame Gusset/Bump Stop Kit from $2300 to $1899.99. In addition, there is now an option for the customer to select a Fox Shock package with all of our Suspension Products.
“We have offered the premier Raptor Suspension systems on the Market for some time now and it is exciting to be able to offer this new incredible pricing and the option to select the Fox Brand.” Jared Hare, Founder
All of the A.D.D. Suspension Products, as well as the full line of Ford Raptor SVT items, are available at: ADD Offroad - The Authority in Offroad Truck Parts and Accessories or call one of our knowledgeable Sales Associates to help you find the system that is right for you.
Engineering the World’s Toughest Yet Stylish line of Truck, Jeep and SUV Products.
If you would like more information about this topic, please contact Addictive Desert Designs at 855-233-8992 or email at [email protected].
Rear Frame Gusset/Bump Stop kit
Why choose the A.D.D. Rear Frame Gussett/Bump Stop Kit?
Additional frame stiffening cross members integrated in to the kit that help support the stock frame in both directions from side to side and from front to back forces.
Our kit is the only one with both directions of support and with the additional frame strengthening cross member that goes front to back and ties into the cross tube between the bump stop towers. This provides a stronger support and allows the bump stop to absorb the extra energy from the bottom out and reducing the chance of stock frame damage.
New lower price with FOX bump stops in the kit - $1,899.99
Our upper arm kit provides a stronger replacement unit for the Ford Raptor SVT and converts the small upper ball joint to a full 1” Race Quality Uniball.
The arm construction is fully welded boxed flat plate for maximum strength and powder coated for extended life. We also use Race Quality Delrin bushings for the pivot in the upper arm at the frame. They fit in the stock location but with the Delrin bushings the life is much greater than a stock rubber bushing. The Delrin bushing also eliminates flex, which gives you a more controlled ride on the street and off-road. A major advantage is the unit will have a longer life than if a Heim or Rod End were used in this location.
Using a race quality Uniball with stainless steel high misalignment spacers in place of the stock ball joint allows for more rotation and with the lengthened post allows for about 1” additional wheel travel. We also incorporate a spacer into the Uniball post to allow for additional droop in the front suspension.
The included Tie Rod Adapter Kit allows for a ¾ heim at the wheel for incredible steering strength. Upgrade to the A.D.D. HD Billet Aluminum Tie Rod Kit and add more strength and significantly reduce bump steer.
This kit was designed to work with the Factory Shocks or you can upgrade to either the Fox 3” internal bypass coilover shock or the 3” King coilover for even better ride and durability. With your Choice of Fox or King shocks, you get the ride quality and adjustability to dial in your suspension.
This is the best kit on the market today and provides the most capable parts to give your Raptor the best handling you can buy.
