New Product Time!
ADDGrant
Arizona
The all new A.D.D Roof Mounts. Designed to fit all 2009-2014 F150 Series Trucks.
Price: $199.99
Call (480) 671-0820 to order yours today!
A
ADDGrant
Arizona
Looks good!
So if I understand it correctly, it's 3 holes drilled per side?
Correct.
---------- Post added at 06:38 PM ---------- Previous post was at 06:11 PM ----------
---------- Post added at 06:39 PM ---------- Previous post was at 06:38 PM ----------
Now available to order online:
FORD F150 SERIES LIGHT BAR ROOF MOUNT
iHaveGas
San Jose, CA
So can these be mounted at any level? I know the last set of roof mounts I got from ADD had to be mounted at the right spot or it would issues rubbing on the door.
A
ADDGrant
Arizona
Looks like it sits fairly low; how's the wind noise with the E-series?
These will produce minimal wind noise, but the lightbars have been known to have harmonic noise due to the cooling fins. To address this Rigid has created inserts for stabilizing the fins and reducing this noise. There is also a trick of putting 1/4" landscape tubing between the fins.
---------- Post added at 10:42 AM ---------- Previous post was at 10:41 AM ----------
No they can't. They have to be mounted at the right spot.
vinnybaja
ny
i need mounts to fit my new 50 inch vision x light widget needs to go to 5w led's when will that be ???? well till then i just have to find some one to make my vision x led work
