Bolt in Rear Frame Gusset Kit
Mesa, AZ
Hey Everyone,
We took our time and looked real hard into the frame bending issues. We developed 2 different bolt in kits. The first kit strengthens the factory frame rails and adds a center frame brace that will prevent your frame from folding. The second kit adds to the first kit. This kit provides an additional cross member and King hydraulic bump stops.
First Kit
main.php
main.php
main.php
main.php
Second Kit
main.php
main.php
main.php
Maxx2893
Rock and Roll Offroad
Burleson, TX
If you were to be rear ended with this on, would it change the crumple zone?
Addictive Desert Designs
Mesa, AZ
Looks good .any price yet?
Thanks, We are haven't finalized it yet, The whole kit is going to be around 2500 with king bump stops.
I'd like a price on this too. Did Ford not fix this issue though?
We will see, lol
This product is intended for offroad use, with that said any time you modify or change the stock frame it can affect the crumple zone. Frames & Uni-bodies are designed to "***" up in the event of a collision. Good for the street, Bad for offroad.
Mesa, AZ
The price has been set @ 1700 for the add parts and 500 for the king bumpstops, 2200 Total, Comes with Grade 8 hardware and installation instructions. Install time is around 3-4 Hrs. As a promotion we are offering free installation for the first 2 Kits sold in house.
Bar
SoCal
No "issue" to "fix". Ford said the trucks in question performed as designed. It doesn't hurt to have something to help prevent it though.
Have to respectfully disagree. I have a slight bend and have spent a while reviewing all my gopro vids (about 2 hours worth of off roading so far with this truck) to see if I can spot figure out what happened. Nothing even remotely close to what caused the bends that some of those trucks got. Then again, my bend is very minor.
To add to that, I have received PM's from others in a similar boat. There is an issue. That issue varies depending on the level of impact. A small bump is a small bend, it seems. If I were the only case of this, I'd vote with you. But I'm not.
Bottom line, I'd highly recommend to anyone to install better stops. Those hydraulic ones look great.
Mesa, AZ
I almost forgot, If you just want the gusset kit and not the bump system the price is 700.
