ADD Ford Raptor Race Series R with 40" RDS or 10 Duallys. Winch?
Rookie
Fort Wayne, IN
Would the Vision X 4.5" light cannons fit on the front instead of the 10 dually lights?
Someone at havoc had this setup I'm pretty sure. It didn't look complete though and I can't tell you who it was. I'll browse through some havoc pics and see if I can find it.
Found this one. Not a good pic for what you're looking for. Those might be KCs but the concept is the same.
Goofball
Just ordered mine. I crunched my factory buber yesterday at work. Picked up the phone immediately and called in to order it.
FullAuto
I have a question for guys running the 40 RDS. Were you able to install the RDS with the bolts on the inside and the nut ******** on from the outside? Or, did you have to go nut on the inside with the bolt on the outside? I had to do the second option with mine leaving the Rigid RDS Security nuts useless. I am wondering if there is a trick to fitting it as Rigid recommends. If not does anyone have a link for security bolts that will fit?
FullAuto
For anyone interested I found these guys and will be ordering a set:
LED Light Bar Security
