Addictive Desert Designs
Our 2017 Raptor bump stop kit is ready to go! Utilizes FOX 2.5" bump stops with 2.5" stroke.
How are you wrapping that around the frame? Perhaps some pics with it in pieces might show more how it goes together?
Few questions;
Thanks
- Have you considered using heims/DOM in-between as crossbrace for adding preload to frame? Is that even needed or helpful?
- One of the main points on encasing the frame on Gen1s was due to the frame design, correct? So is there a need to do the same on Gen2 bump kits?
- No adjustability on the placement of those bump cans?
I dont have any pictures of the individual pieces yet, but it bolts completely around the frame.
Heims have been considered & our engineer & design guys thought this was the best route to go.
Since this new design completely covers the frame, it gives it even more strength, & less room for failure.
There is no adjustment. When you think about it, bump is bump. Full bump is only in 1 location when you cycle suspension. If you adjust a bump stop up or down, you will either bump early or too late. I know some guys like to adjust when towing, but again, bump should be the same no matter what the situation (towing, offroad, etc.)
I was wondering how it bolts around it, it just hard to tell in the drawing.
