Looking to remove my Decals... any advice..
Will_Lyon9
Flower Mound, TX
Has anyone removed their Decals themselves or did you get someone to do it for you?
If so.. Advice??
Cheers!!
Deleted member 12951
Haven't done it personally but its been asked and talked about here multiple times. Everyone says use a blow dryer or heat gun and it comes right off.
TScozz
Aubrey, TX
I removed them on my 2011. Let it sit in the hot sun for several hours. After, start peeling. The slower you go, the better chance of getting it in a full, or almost full pull. Afterwards, I would suggest using some googone for any let over adhesive. Finally, I would recommend a nice wash and wax. Good luck!
Sent from my SAMSUNG-SM-G935A using Tapatalk
RaptorJet
You don't even need to
Use a heat gun if you just leave it in the sun for a couple hours. I did mine 2 weeks ago just peeling it off nice and slow, it came off in almost one piece and left minimal glue. I used a little bit of rapid remover to get rid of the gunk and then removed the film that leaves behind with 70% isopropyl alcohol and it was clean as can be. Image1466037796.456354.jpg
truckarl
You can also use wd40 to remove the adhesive residue but wash and wax your rig afterwards.
