Home Powdercoating Kit
SPRSNK
I Void Warranties
Franklin, TN
I have that.
Buy a cheap 100.00 oven off of craigslist and hook it up in your garage to bake the powdercoated parts in. Cheaper than the parts oven or infrared lights to bake them.
IRONMAN
Well-Known Member
MICHIGAN
Looks like the quality rating is pretty low.
I've always leard that some things are better left for the experts and it would of ended up cheaper if I would have let them do it.
JMO
ekopel
Denver, CO
Powder coating has come down significantly in price IMO, definitely worth going to the experts, they get such a nice clean coat and the prep is where the real longevity comes from.
---------- Post added at 01:42 PM ---------- Previous post was at 01:41 PM ----------
Plus, you've got a nice, expensive truck, so don't cheap out! haha
RSiWORKS
S.C.S. Michigan
Also if the parts are small and it's a one time deal it might definitely be cheaper to have a company do it.
NOW, if your going to be doing quite a bit of powder coating in the future then :iranmaybe: it might be worth it.
onesickpuppy
Ruler of the Earth
I have one and used it for many things. I do not feel it is as good as sent out. Yes, it coats but durability seems less. And I hope you have a large electric oven, the lights take too long and take forever to get material core at temp. For small parts toaster ovens work fine, even better with thermostat to hold given temp. I have a 18" cube of an oven and at times that is small.
My $.02
Lou
Tom
VA
The "high voltage"..."don't not touch" warning is keeping me away from this product. I say, leave it to the pros...
Donk74
Peoria, IL
I have one and have gotten my money out of it 10 fold. Picked it up about 6 years ago along with an old electric oven.
One of my first project was coating snowmobile front and rear suspension components. I did all the little pieces and had a local shop do the two large trailing arms. The pieces I coated have held up add well or better than the pros. It Comes down to prep, better the prep the longer the coating will last. That said, if you don't have a sand blasting cabinet don't was your money on the powder coating kit.
