Fixed the Factory Orange Peel
Deleted member 12951
Come on, you are taking pictures of a mirror.
Looks really good, wow.
crash457
I'm Batman
St. Louis, MO
Looks good. What process did you use? Wet sand or Denim pad? Did you use a paint thickness gauge?
A
AndrewLuz
Santa Rosa, California
I used the CarPro denim pads with a Flex 3401 buffer. I will be using the Flex PE-14 rotary buffer when my 5" plate arrives because it will cut faster then a da. I have a paint thickness gauge to make sure I am not taking too much off. Really what I am doing is slicing off the high points without taking any real amount of clearcoat thickness off. Only about 8-12 microns or 1/2 of a thousandth.
Thanks guys, the truck still has orange peel but it is drastically reduced from the original paint job. Here's another picture. IMG_9026.jpg
crash457
I'm Batman
St. Louis, MO
Thanks guys, the truck still has orange peel but it is drastically reduced from the original paint job. Here's another picture. View attachment 81106
I have considered trying the CarPro Denim pads, but without paint thickness gauge, its just too risky. What compound did you use?
A
AndrewLuz
I am using the Rupes Coarse polish. It works great. The denim pads remove the clear at a very slow and consistent rate. You could probably do it without the gauge. Every time I measure the clear is only a micron or two thinner than before. I wasn't willing to risk that though and I detail for a living.
BRAAAPTR
N. Utah
Wow! That looks awesome! I know what you mean about the orange peel. I noticed my 2011 Black screw had peel.
