05-05-2012, 12:14 AM
#25 (permalink)
Originally Posted by Maxx2893
You can really jack your paint up if you don't know what your doing with a cat bar though, right?
If by "don't know what you are doing" you mean not washing the car first, or not using enough lubricant, or using a dropped piece... Sure I guess you can. But typically you clay prior to polishing.... So any micro marring the claying may add will be easily removed by the polish.
The point of claying is to get the surface free of any and all contaminants that my get ground into the paint during the paint correction process. Dirt on your polish pads is a bad thing. Asking for holograms and swirls.
Also... For new vehicles, you will find the paint is typically just covered in rail dust that should be removed.
I clay the paint and the glass at least once per year. Usually twice.
The Baggie test is the best way to see if your paint needs to be clayed. Stick your hand in a plastic bag and run it across the surface of your freshly washed paint. Feel all bumpy and gritty? You need to clay! Theres something about the bag that amplifies the feeling of the contaminants/fallout on the surface.
