Bed bolts / exhaust hangers
RV67
Corrupt Illinois
Im needing two in front corners OEM bed bolts ( bed to frame mounting ) and the "nut clips" . Also need them to be in like new condition. Located in Central IL
Thanks
I will update the needed exhaust parts tomorrow
Deleted member 12951
The 2 two nut clips in the front are different than the middle and rear. Probably need to specify.
New nut clips have no thread, you cut them when putting the bolt through. I changed all mine and had an issue cutting the thread on a few. I ended up putting the old nut clips back in
RV67
RV67
Corrupt Illinois
Thanks for the heads up ! Learn something new everyday.......
