Rigid Lights D2 LED Light - Diffused Pair *Brand New*
INI
Land, Sea, Air
Bought a bunch of Lights for my Chase Raptor...
decide to go another route....
My Loss your Gain....
60 degree diffusion Lens Pair
250.00 SHIPPED
Features:
Unbreakable Polycarbonate Lens
Cast Aluminum Housing
Plug & Play Wiring Harness w/ Switch
50,000+ Hour Lifespan
Zero UV Emissions
IP68 Certified
No Hot Spots
No Vibration or Bouncing Beams
100% Optically Clear Lens
No Warm Up - Instant On / Off
ROHS Compliant
Over / Under Voltage Protection
Integrated Thermal Management System
Big Power in a Small Package - The Rigid Industries D2 LED Light is one of the most versatile lighting products on the market today. This 6 LED light can be used for virtually any lighting application - from off-road to agriculture. At only 34.5 watts, the D2 produces 3,030 raw lumens of light. Its compact size and shape allow the D2 LED Light to fit almost anywhere. The D2 is available individually or as a pair to suit your needs (select your preferred option from the drop-down menu above).
Diffusion Lens - Perfect for scene or area lighting, our diffusion lens was specifically engineered to project light at a 60º flood pattern. Combine that with our patented optics and you have the best LED flood light in the industry. Like our standard lens, the diffusion lens is made from optically clear, unbreakable polycarbonate plastic.
mkelly984
Would also jump on these if it could wait till the end of the month.
Chainsaw
Ghost of a Raptor Owner
VA
I'll take both pairs of the Rigids off your hands. Sent you a PM.
