Rigid Lights D2 AMBER Light - Driving Beam *Brand New*
Status
Not open for further replies.
INI
Land, Sea, Air
** AMBER **Driving Beam Lens Pair
Looks AWESOME up front or behind the Grill...Makes the stock LEDS look dim
Great for Back up or Chase Rack/ Tire Rack
250.00 SHIPPED
Features:
Unbreakable Polycarbonate Lens
Cast Aluminum Housing
Plug & Play Wiring Harness w/ Switch
50,000+ Hour Lifespan
Zero UV Emissions
IP68 Certified
No Hot Spots
No Vibration or Bouncing Beams
100% Optically Clear Lens
No Warm Up - Instant On / Off
ROHS Compliant
Over / Under Voltage Protection
Integrated Thermal Management System
Big Power in a Small Package - The Rigid Industries D2 LED Light is one of the most versatile lighting products on the market today. This 6 LED light can be used for virtually any lighting application - from off-road to agriculture. At only 34.5 watts, the D2 produces 3,030 raw lumens of light. Its compact size and shape allow the D2 LED Light to fit almost anywhere. The D2 is available individually or as a pair to suit your needs (select your preferred option from the drop-down menu above).
Status
