INI
brand New In the Box...
Bought a bunch of lights for a Chase Raptor and decide to go another route....
My loss your gain.
This light is a Combo Spot and Flood.
comes with all the mounting hardware and wiring looms.
So Cal Pickup or can Ship anywhere.
LOW LOW Price of $1000.00 If you buy the other lights let me know and can work a deal on shipping everything
Spot / Flood / Combo Pattern
Unbreakable Polycarbonate Lens
A360 Extruded Aluminum Housing
Plug & Play Wiring Harness w/ Switch
50,000+ Hour Lifespan
Zero UV Emissions
IP68 Certified
No Hot Spots
No Vibration or Bouncing Beams
100% Optically Clear Lens
No Warm Up - Instant On / Off
ROHS Compliant
Over / Under Voltage Protection
The Original LED Light Bar - The Rigid Industries E-Series was the first projected LED light bar. Since its introduction in 2006, the E-Series light bar has set the standard in the industry through continuing advances in technology and superior engineering. Available in a wide range of lengths and configurations, our flagship is the light bar of choice for everything from light truck / car applications and vehicle race teams to farming equipment and police / fire rescue vehicles. The E-Series light bar is designed to project light at extreme distances while consuming very little power. This 40" version features an extruded aluminum housing with 80 LED's that together produce an industry-leading 16,800 raw lumens at only 160 watts.
Spot / Flood Combo - This light bar features both the Spot and Flood versions of our Hybrid optics system. The Spot version of our Hybrid optics system projects light over great distances in a concentrated beam. It's the most powerful spot-style LED light in the industry. This light is perfect for high speeds or any situation where you need extreme distance. While offering just over half the distance of the Spot version, the Flood provides twice the area coverage. This light incorporates both using our Spot optics in the middle and our Flood optics in the outer sections to provide the perfect combination of distance and area.
http://www.fordraptorforum.com/attachment.php?attachmentid=25629&stc=1&d=1375342159
My loss your gain.
Zero UV Emissions
IP68 Certified
No Hot Spots
ROHS Compliant
