HID retrofits
Jhollowell
Everett, wa
I have a set of HID retrofits that i built. See build specs below
Headlight housing - aftermarket projector
Projector - Morimoto Mini H1
Bulb - Morimoto H1 5500k
Ballast - Morimoto XB35
Wire harness - Morimoto H13/9008
These lights were originally halogen projectors with a separate high beam bulb. I replaced everything with new morimoto parts and the projectors are the bi-xenon which means it uses the same bulb for high and low beams. So the second bulb you see in there is not hooked up to anything. It’s just for show. All the parts except the housing are brand new. They were only installed to test and adjust the lights. The headlight housings were only on the truck for a few weeks until i swapped out for OEM style projectors. These lights are super bright and really look good on the truck. I got a lot of compliments when i had these installed. Any questions feel free to ask. Looking for 950.00 shipped anywhere in the US. Or make me an offer. I’ll take less for local pick up in the Seattle area
Sandfreak520
Washington State
I need to save few pennies but I'll be in market soon....! I'll be in touch nice set up I live just north of you ! How often do you make these sets...? Thanks in advance
Jhollowell
Jhollowell
Everett, wa
I’ve actually got another set that i haven’t started. If you want to set something up i can build them specifically for you with the options you want.
Sandfreak520
Washington State
Thanks I will be in touch soon have to send shocks in for rebuild once that's done I can work some more OT and start setting cash aside for some if your lights ! Thx again
waldoaz
Are these plug and play or needs splicing? My Get 1 does not have the Hid factory lights
